I created two meshes that cut across each other. Does anyone know how to calculate the volume between them? Because the volume measurement tool does not work in this case. I enclose a section photo. I will be very grateful!
The image is not that clear, may be posting a sample file would be better, that said you could try using the ' Extrude Mesh Volume ' tool with the tool setting ' Extrude to Target ' to produce the volume to be measured. ( You could use the Mesh intersection and mesh subtract tools to refine area between meshes ).
Having got the meshed volume, use the ' Convert to Solid ' tool to produce a smart solid. This in turn can then be measured using the 'Measure Volume' tool.
See also the following wiki communities.bentley.com/.../10237.create-a-solid-from-a-mesh.aspx
I have two meshes. One stretched into a second, so as to be completely crossed. Now I am trying to subtract one from the other and get the volume in between, but still get errors, and I'm not able to fix them because they are small holes, which can't zoom. Include pictures, the file is too large.
