Undo Dimension text move
When I have a dimension, I can use the "Modify Element" tool to move the text of the dimension.  If I do NOT do this, the text will auto-center on the dimension when the length is changed.  After I move the text, then it will not auto-center.  How do I reset the text to auto-center on the dimension line?
--Thanks,
--Robert
