Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
MicroStation
MicroStation Forum
Strange problem when filling in data fields ???
Sign In
State
Suggested Answer
Replies
Answers
1 answer
Subscribers
110 subscribers
Views
Users
0 members are here
Offline
Raphael :)
over 8 years ago
Hello
I am facing a strange problem when filling in data fields, please see attached video.
I create an array that consists of several data fields separated by a dash.
I can handle all data fields and fill in the data fields with the copy data field tool, except the last data field in the array.
If I add a additional data field to this array the problem "shifts" to the last data field an so forth..... if adding another data field!
If at the end of the line, after the last data field, I add a character like a dash everything works perfectly.
Gridlock and Snaplocks are off.
What happens here .....?
I need urgently help for this issue.
many thanks
Regard
Raphael
Datafields.zip
0
Offline
RobertArnold
Mon, Oct 20 2014 12:16 PM
I have tried to recreate this and was not able to.
--Robert
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Raphael :)
Mon, Oct 20 2014 1:04 PM
in reply to
RobertArnold
Hi Robert,
Hmmmm, strange.... :)
I tried this also on the workstation of my colleague at office with the same results.....
Tomorrow I can give a sample dgn for further tests...??
Raphael
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
RobertArnold
Mon, Oct 20 2014 2:10 PM
in reply to
Raphael :)
We've neglected to check a major component. I am on Microstation version 08.11.09.459. What version are you using?
--Robert
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Raphael :)
Mon, Oct 20 2014 2:44 PM
in reply to
RobertArnold
I use the same version as you.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Carl Myhill
Tue, Oct 21 2014 5:15 AM
in reply to
Raphael :)
Hi Raphael,
I was able to reproduce using the same build as yourself, and believe the problem is related to the font used ( Consolas.ttf ) in your video clip, I am not able to reproduce using Arial.ttf or Calibri.ttf or the Engineering font from the Bentley rsc file.
Please verify if the problem your seeing is related to Consolas.ttf and that Arial.ttf is OK.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
