Random Elements Become Unselectable
It seems as though several of us in the office have been experiencing an odd issue where we will be working in a file and move a small text element (it could be almost any type of element) and right after it gets moved, the element will disappear. If you change the zoom level, it will reappear, but you won't be able to select it or manipulate it until you exit the design file and get back into it. Any ideas?
MS V08.11.09.578
  • We do have Geopak installed on some users' machines, but not all. Everyone would be using the same version of MS regardless though. I believe all of the graphics cards are the same (same model computers for everyone). NVIDIA Quadro K600 with driver version 9.18.13.3182. I went to NVIDIA's website and they have driver versions with a number like 265.70. Since I don't know much about this side of things, I'm lost. Should I use the 265.70 driver?
    Thanks for the help.
  • The issue you are describing does actually sound like a graphics display issue which could be related to the version of driver being used. I would suggest having a read through the following Wiki which may assist with troubleshooting any problem you are encountering.
    http://communities.bentley.com/products/microstation/w/microstation__wiki/13543.troubleshooting-graphics-display-issues
    If you are a little confused with the versions of driver on your system this Wiki may assist but you might also like to contact the manufacturer or your company's IT professional.
    The following Nvidia driver download page should provide you with a reasonably easy method of locating the correct, latest driver for your Quadro K600 graphics card. This should also show the extra information you require regarding the version numbers etc.
    http://www.nvidia.com/Download/index.aspx?lang=en-us
    I hope this information is of assistance.
    Andrew Bell
    Technical Support
    Bentley Systems
  • just a shot in the dark try going to user preferences and turn off antialiasing  for both tick boxes , restart and see if the same element same file give you same behaviour...
    I used to get this with zoom in out object disappear  and reappear...  turned of antialiasing and doesn't happen any more with my graphics card...
    might work got nothing to loose...especially if you  don't use that feature... you can always put it back they way it was if no effect...
    Lorys
    click link to PM me
