Hello!
when user wants to detach all references by referece detach all key-in or from dialog the modal dialog "do you want to detach ALL references..." will appears...
Is there any way to detach all references without modal dialog poping-up?
And else, if once user chose the optoin "don't show this message again" now this modal dialog can be again activated/deactivated?
thanks
Couldn't get keyin to work but recorded simple macro
keyin would be
<macro detall>
This works very well
' detach all refs and close dialogue macro'Lorys Lea public domain 13/11/2014Sub main Dim startPoint As MbePoint Dim point As MbePoint, point2 As MbePoint MbeSendKeyin "reference detach all" MbeSendCommand "MBE1 CLOSEMODAL OK"End Sub
I could not work out how to make this a single action keyin script because the MbeSendcommand "MBE1 closemodel ok"
is what does the ok really fast so you don't have to... put it on a F key and you don't type anything.
Enjoy...
Lorys
You can "disable" that confirmation dialog from opening by using the "command"
mdl keyin calculat;calc userPrefsP->displayMsgPrefs.detachAllRefs=1
Then execute the command:
And if you want to "enable" that confirmation dialog, you can use the "command":
mdl keyin calculat;calc userPrefsP->displayMsgPrefs.detachAllRefs=0
These statements can be concatenated together in one string:
mdl keyin calculat;calc userPrefsP->displayMsgPrefs.detachAllRefs=1;reference detach all;mdl keyin calculat;calc userPrefsP->displayMsgPrefs.detachAllRefs=0
great final line - straight copy paste.
I just changed the "ALL" to only be models that had BR in the name - Reference Detach *BR*
