Coming from AutoCAD, I am kind of confused where hatch patterns are located in Microstation. Then, I realized that basic Microstation does not have any included hatch pattern files or cells save the standard single line or cross hatch.
Does anyone have, or do you know where I can get for free a cell library with standard-type hatch patterns? Things like concrete, honeycomb, sand, earth, metal cross section etc... ?
Thanks.
-7F degrees in Denver, CO - BRRR!
Hi Ivan, of course the library is included in MicroStation installation. If a simple hatch or cross hatch are not enough for your purpose, use Pattern Area tool and use e.g. areapat.cel library, which is located in ...\WorkSpace\System folder. In the mentioned folder (precisely told it's C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\ or similar) more cell libraries are available, for patterning also some others like archpa.cel, or geompa.cel or igespats.cel can be used. With regards, Jan
[Note: Edited to correct mistake in folder name.]
I have that folder, but all sub folders under that are empty. No .cel or .dgn files (or otherwise) exist. This was installed via a corporate roll-out install, so I have no ability to set install options.
I've emailed our IT guys, but that could take days, if ever, for them to respond. Can you attach those default cell files here? Thanks.
Hi Ivan,
Unknown said:Can you attach those default cell files here?
Well ... probably I can, but I don't want to do it this way ;-)
There is better alternative available: On SELECTserices web go to this page (Bentley Library content), choose MicroStation + Data Sets + English and from search results choose MicroStation XM General Data Set. I have not found V8i dataset available at this old library or at new BE Communities library, but these patterning libraries are the same for many years.
BTW You can check what searching with MicroStation + Cells + All conditions will find ;-)
With regards,
Jan
Don't forget that MicroStation allows users to select AutoCAD .pat (Pattern) files for Patterning Area.
Only issue is you can't see what they look like till you pattern.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
