Coming from AutoCAD, I am kind of confused where hatch patterns are located in Microstation. Then, I realized that basic Microstation does not have any included hatch pattern files or cells save the standard single line or cross hatch.
Does anyone have, or do you know where I can get for free a cell library with standard-type hatch patterns? Things like concrete, honeycomb, sand, earth, metal cross section etc... ?
Thanks.
-7F degrees in Denver, CO - BRRR!
Erick,
The patterns, and a lot of other resources, are available "out of the box". If you just open MicroStation with the defaults the delivered AutoCAD pattern library is available with no navigation required. Once you start messing around with the configuration the default paths will change and then you have to start navigating to different folders.
Rod WingSenior Systems Analyst
Ok
It may be better for you to post any issues you have as a new discussion in the main MicroStation Forum. It would also be helpful to identify exactly what you are trying to perform in this new post along with some example files, screen captures and the software and version you are currently using.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
This Forum exists to provide help. Mostly, it's peer-to-peer help from other MicroStation users. Occasionally, a Bentley Systems employee will also assist.
Hany Bakheat said:I hate Bently stupid programs
We can't help a mis-spelled opinion. Stick with questions.
Hany Bakheat said:I just enforced to use this awful software by my clients
If you think MicroStation is so bad you can cancel your contract with those clients and revert to working with SuperCAD.
Hany Bakheat said:I am trying to figure out how to match two hatches but nothing!
Here is an updated path for the cells in MicroStation CONNECT
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Cell
