Version 08.11.09.459
I have a DGN containing 10 Sheet Models and I would like to save the file so that each model is extracted to it's own DGN with all references merged
How can I do this?
Unknown said:The result should be 10 separate files with all references merged into the master. There are 80 dgns each containing up to 10 sheets so it is a huge task if I have to do this manually.
So not export but to merge. No one design file but 80. What other facts, conditions or requirements have you not told us?
Without true exact information nobody can provide you correct asnwer :-(
Unknown said:Surely this should be possible?
Many things can be done and issues solved, if not by particular tools, so using batch process or VBA, but it's still far from "surely" and a working solution is not always simple and easy.
In my opinion you have to split the process to two steps:
With regards,
Jan
Your suggestion is exactly the way I don't want to do it as I don't have the time for that. I'll have to find a way with VBA then
regards / Thomas Voghera
