I've finally created some custom linestyles. Most of them look good except 2. One in particular has the text overlapping the dashed line. I can't find anything different with it than the others I've created. Can you look at the attached screenshot and tell me how to adjust it? Thanks, Lisa
Check the text justification of the GAS symbol.Make sure if Base Stroke Pattern was set during Point creation.
I have created a sample linestyle and is attached for your reference.• Create a Stroke (e.g. GStroke) with Dash and Gap pattern.• Create a Point (e.g. GPoint), make sure to set the already created Stroke as Base Stroke Pattern.• Create a Symbol (e.g. GSymbol)• Create a Compound (e.g. GCompound) and add Sub-Components (GStroke, GPoint)• Create a linestyle Name (GAS) and link to GCompound.
If you still have issues, attach the linestyle file.
test.rsc
Answer Verified By: LLM
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
