I am using Microstation V8i SS2.
I have drawn some lines with a linetype according to my local DOT level control. Some of the symbols in the linetype are upside down and some are partial symbols, see attached image. How do I turn all symbols upright and eliminate partial symbols?
This is a two step job,
First the top row can be fixed with the modify linestyle icon ( already mentioned this week this forum) and it will let you shift the symblol on the right a little towards the left until it looks complete...
if you cant find the icon its keyin is > modify linestyle icon and choose the last icon on the right and drag until full shape is achieved.
Second bottom row, you need to change the line direction there is a tool for this under modify curves or the keyin > change direction
follow the prompts and screen arrows...
Lorys
Answer Verified By: CADTech1
in addition to Lorys' response:
When you are allowed to make changes to the line style definition: to avoid symbols being placed partially, you could consider to untick the option: Clip Partial in the Point Symbol definition of your line style:Note:Thoroughly test in a non-production environment firs as doing so, may affect the display of the corners of your connected elements like line strings, complex chains and shapes, HTHRegards,Henk
