Global Display / View Display
I don't know if some setting has changed in the past few weeks, but my global and view display is not working properly.  When selecting the global display from the View Display dialog, shouldn't the selected levels turn on/off in all the open views?  Something is preventing some levels to display.  I either have to double-click each level to turn it on ( making it the Active Level ) or if the levels are on in another view I can copy that view.  Either way, the dialog box is not working as it used to.  Any suggestions?  Thx for you time.
  • on the View Display dialog there is a Dialog Settings button in the bottom right of the upper section, this has 4 check boxes near the top, the last one says Follow Active View. If you uncheck this and close the Dialog Settings box, you will see View 1-8 toggles at the top of the View Display dialog. any view not currently open will be grayed out, but open views can be toggled to include their level display. all toggled views will be affected when ever a level is turned on or off. you will also see some levels which display gray, if they are on in one or more view(s) but also off in other views.
    Brent
