Replace cell command
There is a command line utility to replace cell with another
msbatch repcell.ma <DGN_file> <cell_library> <y | n> <cell_to_replace> <replacement_cell>
Is it possible to use this same syntax in GUI also? Existing key-in for repcell.ma "replace cells extended" is hard to use as it requires to select or identify cell for replacement.
Parents Reply Children
