I would like some ideas on how to create a linestyle containing two lines in the color red, with fill in the color blue. This will be used in a mapping environment to create the roads. I do have it in ArcGIS but unable to create in MicroStation. Any suggestions?
Would a Multi-line work for this? It can be set up to the desired colours using the Multi-line Styles Dialog...
It is a bit clunky but it can be done. Corners and sharp angles are a problem.
I created a Stroke, Point & Compound to accomplish this.
A Blue shape (1x12) for the inserted Symbol (using RGB values, so the Color Table would not affect it.)
Used the inserted Symbols Color (Blue).
Created 2 offset lines, Line Code 0 (+6 -6 for Road Width (12)) in the Compound.
I made other adjustments to make it all work the best I could, so you are going to have to look at the components to see what settings I made. I have attached the BlueRd.rsc.
Set your active Wt. & Color to the Lines Color & Wt.
0550.BlueRd.rsc
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
