Linestyle with fill between two lines
I would like some ideas on how to create a linestyle containing two lines in the color red, with fill in the color blue.  This will be used in a mapping environment to create the roads.  I do have it in ArcGIS but unable to create in MicroStation.  Any suggestions?
  • Ron,
    Thank you, a very interesting idea!
    All the Bentley applications unfortunately requires Linestyles and not providing the ability to select display styles.
    Max
  • Isn't this just like a multi line? But with a multi line you can have whatever infill colour you need and not just blue.
  • Hi Clive,
    With Multi-Lines you are limited to linear elements. Arcs and curves aren't supported with Multi-lines, as Nasir mentioned. My method works with curves and arcs, as well as lines.
    You can use any colors you want when you define the Display styles. In my example I showed two different color combinations, red with blue infill and yellow with green infill.
    Ron
  • George is on the right track here I believe. The only thing I would change is not using a point element for the fill. Instead I would create another stroke pattern and apply a width to it . See screenshot for this option. This will produce a wide line that can be placed between the 2 border lines. The great part is that it will be smooth around arcs.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • Unknown said:
    Hi Max,
    I came up with a simple method to "fake" multi-color linestyles using Display Styles and self-referencing.
    Here's a short video that explains exactly how to do it.
    (Please visit the site to view this video)
    Cheers,
    -Ron
    Example dgn from video:
    (Please visit the site to view this file)
    You are brilliant!
    Lorys
    click link to PM me
