I am currently using V8i SS3 and am looking to draw sections using the section callout tool. Having clicked on the tool the 'place section callout' dialogue opens. When selecting 'drawing seed' only 'none' appears in the dropdown box instead of a list of options. Is there a setting in my configuration that's wrong? How do I retrieve the list of seed files in the 'drawing seed' drop down list?
Is there an idiots guide to creating custom callout symbols, using dgnlibs and seed files?
Strange that the 'Create Drawing' option can be ticked. If you proceed and place a section as an example, the Create Drawing dialog should pop up, does it give a file (dgnlib) name for either of the Seed Model fields in this dialog? In the 'create drawing model' section of the dialogue the seed model is 'ModelSeed.dgn. Drawing'. In the 'create sheet model' section of the dialogue the seed model is 'ModelSeed.dgn. Sheet'.
Is the MS_DRAWINGSEED_LIBLIST variable set up to point directly to the files or just to the folders?
The entry for MS_DRAWINGSEED_LIBLIST is C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\PHGBGR\Standards\dgnlib;C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\dgnlib
Thanks again Conor.
