Is it possible to compress a file upon opening it? A simple yes or now will suffice. Thanks
regards / Thomas Voghera
You could do this from the batch processor while in another file or write a script file and run it while in another file...
Microstation used to have this feature from the microstation manager so you could compress files or folders without opening files.. but its nolonger available from the manager
so now you can only do it the way I described...
Lorys
Hi Bear,
Unknown said:couldn't you use the autorun vb to run the compress keyin on opening a file?
Probably yes, but the request is "simple answer" and to use helpers like autorun requires a proper workspace configuration, so it's not "simple solution for a user". But it would be the right solution in the case, if a compress on exit will be not sufficient.
With regards,
Jan
