Hi all
I've displayed surface triangles as mesh and turned on the thematic height display style.
I've changed the legend to be not dynamically and I've changed the elevation range to a number of colors and the range values to every meter.
I've put the legend as a persistent element in my drawing.
The values of the legend displays up to 5 decimals. How can I change the number of decimals to be less than 5, f.e. zero decimals or 2 decimals?
Thanks for any reply.
Jean Castro
Hello Jean,
Have you tried changing the Accuracy value in Design File Settings? To do this;
I recommend that you change the display style settings in the Thematic Display Dialog
Opens when you click the magnifying glass icon next to the Thematic Display drop-down in the Display Style Dialog.
There is also a large amount on information in the MIcrostation Help on this issue.
http://communities.bentley.com/products/microstation/f/19565/t/76123
Regards.
