Hi, can anyone shed some light on a small annoyance I have with underline spacing please? When I apply underlines to a piece of text using the text editor I get no underline spacing (underline touches the text - not good!), but when I apply it using the change text attributes tool, it comes out under the text and not touching it (which is good!). The trouble is that applying it using the text attributes means that all the text in that node gets the underline. When I want only to underline part of the text, I can do this using the text editor but I get no underline spacing. Can anyone tell me how the two methods differ from one another? I presume they are using different criteria to apply the underline and I would like to be able to adjust the settings so that they come out the same. Any advice would be much apreciated!
Hi Wendy,
in terms of underline spacing there is no difference if you apply the underline in Text editor dialog or using Change text attributes tool: In both cases underline spacing from a text style is used (defined in Text Styles dialog, tab Under/Overline). But what is not quite clear from a user perspective is what spacing value and when is read from the text style.
If you just start typing, style (none) is probably used and this style has define the spacing as 0 ... so the line touches the text. To change it, you have to go to Text Styles dialog, change the underline spacing value and to press Activate button. The change in the spacing should be copied to typed text dynamically.
Similar situation (but a bit more weird) is if there a text exists and you want to add the underline to a part of the text. You are right you have to use Text editor again in such case, not Change text attributes tool. General workflow which should work is:
If you are in a situation where just a few text styles exist, you can simplify the process if you will create two versions for every style - one not underlined and the second yes. In such case you will be able simply assign proper text styles to parts of text without jumping to Text Styles dialog.
With regards,
Jan
Answer Verified By: WendyH
