Hi all,
I have well over a hundred single text elements following a railway depicting chainage every 5m. The text follows the route of the railway. At the moment all the text is the same i.e. 0m, so what I am looking for is away of changing all the text automatically..so it reads 0m, 5m, 10m etc. I have started the process manually but it's going to take me a long time, and errors could occur. I have tried grouping the text, but you can only edit each text element individually. I would like to have all the text as one element, and to beable to copy the text into excel, with a couple of mouse clicks create all the chainage and then copy & paste back into Microstation while maintaining the location & alignment of the original text. Any ideas?
Matt
Unknown said:Any ideas?
How about a tool ...
Unknown said:I would like to be able to copy the text into Excel, create all the chainage and then copy & paste back into MicroStation
While I understand that would be an attractive approach, there is a potential problem. If the text elements are not in the correct linear sequence, the values will be updated in the wrong order.
Suppose the text elements were digitised like this:
T1 -- T2 -- T3 -- T5 -- T6 -- T4 -- T7 -- T8
Then the annotation would end up like this:
0m -- 5m -- 10m -- 20m -- 25m -- 15m -- 30m -- 35m
Answer Verified By: Matt2003
Unknown said:A tool would be useful. It would be good if one existed
Given that you mix units of measurement chainage and metres, it's clear that you work in a very particular sector of the rail industry. If you're not aware that such a tool exists, then it probably doesn't.
Try Phil's suggestions first. If they don't do what you want, contact me by e-mail.
A chain is a unit of measurement in the British Imperial system. It has somewhat arcane usage. A chain is 22 yards.
Unknown said: Matt2003 A tool would be useful. It would be good if one existed Given that you mix units of measurement chainage and metres, it's clear that you work in a very particular sector of the rail industry
Chainage is a term used a lot in civil especially here in Australia ( the USA calls it stationing) its from our old survey days when we used real steel chain with links and a chain man to measure standard lengths using the length of the chain ( not 22 yrds) I think they were in 100 ft lengths but well before my time..
But the term chainage has stuck here for civil works ..
Lorys
Unknown said:The term chainage has stuck here...
Well, shiver me timbers! But is that simply terminology these days, or is it an actual measurement (22yards) that you mix with metric measurements?
It's a peculiarity of the UK rail industry that they mix units in different ways. For example, I believe linear measurements are termed chainage but expressed in metres, but sometimes miles are used. Curved track radii may be measured in chains. Modern constructions are metric.
Again as I said before Chainage is NOT a unit of measure its a term that is used instead of STATIONING...
We non USA countries call stationing , "chainages." nothing to do with the old measure unit of a chain ( 22 yds...) No doubt they have a common root being both the word chain ... but chainge means station as is used in stationing when using Bentley Inroads or InRail...
