level lock does not applies shared cells
Hi all,
I have a key-in script to select all elements on a locked level and then calculate the length of the selected elements:
fit view extended;lock level on;active level = ln_piling;choose all;measure length;xy=0,0;lock level off
When I run this key-in it is not only selecting all the elements on the locked level [ln_piling] but it also selects shared cells on a totally different level. When I drop the shared cells to normal cells everything works fine. Test file available via e-mail request.
Is this a bug or is something wrong with my key-in script.
MS:08.11.09.654 / Inroads 08.11.09.788
Jean Castro
  • Unknown said:
    Hi all,
    Jean Castro
    Another reason to not use shared cells...( my pet hate see previous rants) ....
    Alternatively just use the power selector to select the level and deselect  shared cells from the type  then use the measure length tool to give you the length of you selection of all elements on you chosen level excluding shared cells
    or if you still want your script then  modify your  keyin  takeout the measure part , run your script
    then through the power selector  unclick shared cells , then use the measure tool to get the measured length without  the shared cells.
    You could record a vba macro of  what you just did  including the modified keyin to select all and the level of choice  ... or just use the select tool to modify your select all  whilst running  the vba macro recorder..MStn basic wont capture  the steps... I tried  so as to find the hidden keyins  ... I did find one with basic  to switch to remove mode
    POWERSELECTOR MODE REMOVE, you could put that at the end of your script
    fit view extended;lock level on;active level = ln_piling;choose all;xy=0,0;lock level off;POWERSELECTOR MODE REMOVE
    then in the power selector manually toggle off the type ie shared cells
    and now as everything you want is in a selection set you can select the measure length tool or key in manually measure length and data point and you'll get the length of your selection..
    Lorys
    click link to PM me
  • Hi Lorys
    Yes I know... shared cells... the came over from a dwg-file, copied them into my dgn-file.
    The script is all about the measure length and area so I can get the result quick and fill them in a material bill. If have to break it up then it is best to do everything step by step. I think shared cell are the problem to deal with.
    For now I will screen the dgn-file first on all shared cells en drop them to normal cells.
    About VBA... I have no VBA-brain. Me stupido...
    Thanks for your insight.
    Jean
Reply
  • Hi Lorys
    Jean
  • ok still run your keyin , but then look at the power selector and choose the remove option or just click off shared cells
    the selection set should still be active so clicking on measure length tool or keyin measure length  will still give you the answer you seek without shared cells dropped as they are unselected..  its only 3 or so  clicks extra  to your script  not really going to slow your productivity  for one file ...
    You dont  need VBA brain to record a vba macro it either does what you want or it doesnt and  if you can read basic  and can recognise a keyin command then in the vba editor you may just  find the keyin you need  about 8 out 10  times this works for most tasks...
    my approach is look in help for a command
    then look in the keyin window for keyin combinations or sequences then look for set item tool settings  for  number variables to the keyins ( search this forum for set item tool settings and Ask Inga )
    then I try a simple basic macro recorder to see if I can get a keyin ( but Bentley will do away with basic sooner than later)
    then last of all I try VBA macro recorder...
    and if its something  I need to do often I will take all the keyins and make and "action string " script and assign that to custom Function Key ...very very cool ...I love the F keys...I even use them  to run macros , vba , mdls, script files etc
    Very very big time saver...
    Lorys
    click link to PM me
