Lost Toolboxes Etc.
Hi
Today I opened mstn and found a bare workspace. All my toobox settings were lost - none were open. I'm using the same workspace/user/project etc. on open as when I closed out last night.
My Key-in spot is gone. The bottom where status messages, key-in window, and where I parked AccuDraw, were all gone except for the status messages. Further, it seems to not fit into the available space anymore - if I dock AccuDraw it is off the screen to the left and I can't see it. There is no place to change views anymore.
What happened? How can I restore it to how it was? I can open the toolboxes again (although I can't seem to find the one that open the Model dialog, it only wants me to create new models from the Models toolbox), but the AccuDraw and key-in missing have me concerned.
I don't know of any environment changes, though IT maybe installed a Windows update last night - I do not know.
V8i SS3
thanks
  • Thanks for the advice on the variable. I will add it to my ucf.
    But, look at this - "User preferences file was left open. Closing it (click here for details.)
    Application "USTN" opened the user preferences file and did not close it. This is not normal behavior. Please notify Bentley Systems or the author of the application." This appear in the status window today. I'm thinking this is how the upf got corrupted ...
    hey Bentley?
  • Rene,
    There is a variable you can write to use a seed file  to rebuild the upf..
    I have this in my my workspace config have saved  clean copies for all my users  onto the network
    if things get out of wack as the  seem to do I an just delete the user.upf and mstn rebuilds it with the seed version..
    alternatively ..
    delete your upf file
    restart mstn  set it up the way you want it to look but 1. dont run any applications 2 dont open any more dgn files after setting up your workspace settings and docking of tols etc
    save setting get out of mstn entirely
    now find the your user.upf  file and  make a duplicate and rename the extension to seed  or .spf  ( so you know this is your seed ) and you can just copy and rename it  back to upf ( after  you first deleted the current one)
    Now this never fixes the cause of why it got corrupted that will need investigation but it will get you back to work fast..
    I have the variable for the spf at work ( I;m at home now) but you can search this forum for spf  or user pref seed  variable
    Lorys
    click link to PM me
  • delete the user pref file for the user.
    set up how the user wants his prefs layed out then copy the new  CLEAN LEAN user pref file ie username.upf
    renamed to usernaname.spf and save it on the server
    just tell the workspace cfg variable to use the
    MS_USERPREFSEED= "nwtwork drive letter:/network folder/user /seed/username.spf'
    tells it where to find the seed file
    So now if there is a problem  I now delete the users.upf and restart mstn
    and their original setup is back...
    Lorys
    click link to PM me
