It's strange and not comfortable when drawing shapes , smartlines ....
When you draw - if you want change view level display it not breaks command
same when you change display in references,
but if you want to change display in raster manager ( to turn off raster in view ) the command breaks your drawing
Is this a bug and can be changed or the raster manager have other rules than others ?
Unknown said: It's strange and not comfortable when drawing shapes , smartlines .... When you draw - if you want change view level display it not breaks command same when you change display in references, but if you want to change display in raster manager ( to turn off raster in view ) the command breaks your drawing Is this a bug and can be changed or the raster manager have other rules than others ?
Martin,
I have a very cool work around if you have twin screens in view 1 screen 1 set the raster off before you start in view 2 screen 2 set the Raster on
Now start tracing in either screen should work and give best of both worlds without problems... just change working either screen and scroll zoom in to see detail
Lorys
Answer Verified By: martinezx
