What is it that changes the scale of reference files when I initially attach them? This morning I attached two files, both at 1:1 scale. The first came from an AutoCAD export. Somehow it acquired a craving for metric units. I attached it, it came in to the next county over (waaaay over there), and when I checked the scale it had changed itself to 1:3.2808. The next file I attached changed its scale from 1:1 to 1:10, so it was in another state when it came in.
What is responsible for this? How can I avoid it in the future? I don't mind the occasional miscue because hey, it happens, but two for two to start the day? I had the same thing occur numerous times last week with various files.
thanks. mstn V8i SS3
Couple of things to look out for
Autocad files often are export wrongly especially the units..
also when you attach a dgn reference read every part of the dialog box
sometime it uses custom scale from annotation scale or drg scale thinks your using it for detailing ..
or the scale you last attached a ref at .. I see this too but not exaclty sure where or why just read everything dont just ref at attach and enter and data point...
also check the geographic datum in the active file and independantly open the ref and check if it has a geographic coordinate system attached
if they dont have the same geo coord you need to reproject the reference file..
or you need to assign a geo graphic coordinate system but you need to know what it should be in each ( get that info from the originator.. )
Lorys
the 1: 3.208 thing is a meters to feet ratio so your ref file must be in meters and your active file is in feet or have I got that backwards?
Next time it happens go and open the naughty ref file in an other session and examine the units see if the match what you expect.
The other times if they came form autocad is the naughty acaders dont draw civil stuff 1:1 so the scale the world down to fit a sheet so nothing is geographically correct anymore..
So if they want it 1:10 the scale it all down and you attach as a ref file and its never going to land right
other times its that your in meters the acad have drawn in mm so its a 1:1000 times wrong or they drew in cm so you 1:100 wrong with refs
I get this all the time from acad especailly if the just use unitless and treat everything as mm so a 1 m line in 1000 units long ... I often get the 1:603 which is the inches to meters issue...
open the auto cad converted files independantly one at a time check the units and measure some know distances if its wrong or strange its because the original autocad files we unitless and mstn has tried to compensate and tell the file it is either m or feet... you should now change the units in settingd>design file> units
and change to real units it should have been in acad..., oops check coords too before you change things assign coordinate system too... ( always a good thing in survey work)..
Do this to both files especially acad export dgns before yopu ref attach them..
Now go back to your original active file check your design units , and geo coord system is set.. now ref attach the other exported files.. both should work fine now..
I get this even with acad files not exported just ref attached they are unitless but drawn as if in mm so they are 1000x too big or too small and dont geo ref properly into my default meters file I have to play with the ref scaling until it works also the 603 one is when the acader has thought it was unitless but was actually in USA inches a real pain in the Butt.. but acad is not smart enough to pick this up until mstn use it as refs...
Not much else you can do.. what I do is get it right with ref scale and rotation then fence file to new file and wow its now corrected then blow away the original to superseded folder for QA ref purpose or just kill it... and use my Fence filed version instead then add our colour table attached instead of the the acad one...
