Can some please explain why or how you uses the following in element templates
Levels you can have a primary level which seems to be the level the template will take when it is used, yet you can added multiply levels below this which dont seem to have any function at all.
This also seem to apply to all the attributes within the templates including colour fill, hatching etc
many thanks
Mark
Timothy Hickman
Main: 877 627 3772|
Let me first say that I have not yet studied templates.
But I do know microstation well enough to say
Single element shape has the fill and boundary as an attribute of the element and hence are both on the same level but the fill is an attribute that can be toggle on or off like colours can
you cannot have the outer and the inner on two levels and be the same element of a shape..
This can only be acheived if you have two shapes that are the same one on level A with no fill say is red, the other shape super imposed is on level B and is a red filled or green filled shape, now select both and control G to group them the result is a cell ( graphic grouping) and you can make the levels on or off independant of each other but the graphic act as an element if you move scale or delete.. if you turn this into a real cell not a graphic grouping then you can recall it with all the settings preset ie colours level names and use place cell to add it to a drawing but make sure your level names in the cell make sense to some one who didnt build it..
See my attributes via information or properties tool of a filled shape notice only one level name is available.. ie level A
Lorys
