Can some please explain why or how you uses the following in element templates
Levels you can have a primary level which seems to be the level the template will take when it is used, yet you can added multiply levels below this which dont seem to have any function at all.
This also seem to apply to all the attributes within the templates including colour fill, hatching etc
many thanks
Mark
Lorys
Thanks for your reply. I understand the principals your are saying, but i was investing element templates when they first appeared and found you could add multiply levels colours etc (see below) but could not find how to use them, the only thing i could do was add them. I have now been asked to look again at element templates and thought i would try the forum to see if anybody new how to use or what the additional levels colours etc were for.
We use the template levels to designate different states of different sitework line styles. For example, a template for Storm Drain - level 0 for existing; level 1 for proposed and level 2 for abandoned - one template containing 3 different line styles, weights, etc.
Timothy Hickman
Main: 877 627 3772|
