Im quite new to MicroStation and I've got the following thing:
When I only want to change the level a line or complex chain I use "change element attributes", and only check the box in front of "level". Then I choose the level to which I want to change the line or complex chain to.
When I follow those steps, the command changes the linestyle as well, while that box is unchecked.
Can someone help me?
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Answer Verified By: Phil Chouinard
I agree with you Jordy.. this has always been something that has frustrated me, as well as many others over my ten+ years using Microstation,
Don't know why its be implemented this way.
Stands to reason that if its un-ticked, then it should remain as original, that would give you freedom to choose.
