In Microstation V8i, is there a way to combine "Copy/Increment Text" and "Add Link to Element"? The result I would like to see as I add URL links to a series of elements is something like this: www.webpage.com/1, www.webpage.com/2, www.webpage.com/3, etc., as I click from element to element while adding links.
Please let me know if this can be accomplished.
Unknown said:Is there a way to combine "Copy/Increment Text" and "Add Link to Element"?
Probably a VBA macro could combine those commands for you.
Hi Jeff,
as Jon wrote, there is no such tool available in MicroStation, but you should be able to implement the required functionality using VBA.
The solution will probably be not straightforward, because there is no VBA API for Project Explorer and the establishing of links to element, but there is a workaround mentioned by Mark Andreson in this discussion.
With regards,
Jan
