Is it possible or ever likely to be, to use regular expressions with Level filters?
for example;
[^abc], which is anything but abc, or negative lookahead: a(?!b), which is a not followed by b
Alternatively, is the a method of doing this type of selection?
as far as I know regular expressions are not supported by Level Filters, but general not so complex expressions can be used. They are described in "Using Filters" chapter in MicroStation help file.
With regards,
Jan
Answer Verified By: cweber
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
