I turned on fill in View Settings because an opaque shaded area I placed was not showing its fill, nor was it letting me turn it on in Element Properties. Fine, that much worked. But now every time I place a closed SmartLine it creates an opaque fill. Then I have to select every one, go to properties, remove its fill.
Is there a setting that I can use so that fill is not automatically created for closed SmartLines, shapes, whatever? Or is all that extra work normal?
thanks.
Don't forget that if you want to change the fill of an existing closed shape, all you need is the Change Element Fill Type tool.
If you change the Fill settings here it will go across all the tools from that point until you change it somewhere.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
