I work remotely from home. I recently have changed my "connection" to work from a VPN to a remote virtual machine. The remote virtual machine is great and much more stable.
However, every time I open Microstation for the first time, both Application windows open on the primary monitor. This was not a problem when I was on the VPN. It's just a minor nuisance, but a nuisance all the same.
Microstation SS2
Nvidia Graphics card - Geforce GT 640
Windows 7 PRO
Intel i5-4430 @ 3 GHz
I think your user preferences are on the virtual machine and you cant save changes..
Try this test drag a tool pallet to the top bar save setting exit msnt completely and restart microstation if the change has been retained then its not the user pref file and we'll need to think of another possiblity....
Lorys
I can save changes. I tried the test, as you suggested, without fail. Thanks anyways. I'm at a loss as to why. The virtual machine has to be the key, since that's really the only change, but I don't know what exactly.
ok then ...
by default which is the primary monitor left or right? in which screen does mstn splash show up in,
when the mstn manger opens which screen does it land..
When you tell mstn in prefs that you want two sessions at once... does it then next time create both screens on the same monitor?
Can you drag one window across to the other monitor do a save setting and restart mstn .. did it hold? what does revisting the pref show ticked or unticked?
Back in the old days with win 95 we had to tell windows that the screen was twice as wide in windows desktop view setup ie the resolution double wide not mstn, then in mstn dragged the second window over to the right hand monitor maybe that would work in your case too...
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Connor McShane
