MicroStation PowerDraft V8i - Version 08.11.09.459
When using the place note tool with curved leaders, is there a reason that the terminator will flip when the note is moved? The terminator also flips when creating notes sometimes when you are snapping to objects. This becomes very frustrating when moving details to fit on sheets.
Terminator flip:
Note settings:
Check to see if the terminator cell being used is a point cell or graphic cell. One will rotate, the other will not. This has been a problem since V4.
This discussion is over 6 years old and relating to an old unsupported version of MicroStation. If you have an issue that you wanted to discuss relating to this I would suggest that you post a new discussion and include details of the software and version you're using along with example design file and screen captures to help explain what you are encountering.
MicroStation Forum best practices
