I am using Microstation v8i 08.11.09.655 (also used earlier versions). When I attached a tif file, it shows some lines. I have no problem attached jpg, jp2, pdf files.
Don't know the reason. Played with the "Raster Manager" under "Preferences", no change. Delete all cache file, no change.
See below. I even roll back the video card driver, but no change too. If someone has similar problem before and know the solution, please let me know. Thank you very much.
2.tif
Mathieu,
Actually it is released on Jan this year. See below for the screenshot. I don't think the bug has been fixed.
Charlie,
Ah ok, thanks for the info.
But it is possible that the fix hasn't been taken by MicroStation 08.11.09.655 given that it is in a sub-component with is own building process and version, not directly in MicroStation.
To be sure, search IPPGraLibs.dll and check its version (right click on the .dll, select properties and go to the Details tab).
The fix has appeared in version 08.11.09.409. If the version is less than that then you would unfortunately have to wait for a new MicroStation.
Mathieu
