Hi all,
I am trying to make a batch process to fence file the contents of a file to a new file of the same name in a new directory. I have already:
ON=*;SELVIEW 1
FIT VIEW EXTENDED< CR>
PLACE FENCE VIEW 1
FF=FENCEFILE:
POINT ABSOLUTE
I have predefined FENCEFILE = C:\temp\$(filename(_dgnfile)) inside the pcf and yet the process still tries to create a new file without any filename [C:\temp\.dgn]
How do I get the filename to be exported as the name of the original file please?
Thanks in advance,
When using a variable as part of a key-in, you must let it know its a variable.
See http://communities.bentley.com/communities/other_communities/askinga/w/askinga/using-the-expand-keyin
You are using one of the Special Key-in's that can take a filename and path - but it might be assuming that FENCEFILE: is a path variable. Generally, when used in this manner, the software expands everything before the colon to a path and then wants a filename following the colon.
Answer Verified By: Ted Gabriel
