I am using Microstation v8i SS2.
I have text that I copied from one file to another. In the source file the text looks yellow on the screen and in the destination file it looks cyan in color. I checked the element properties side-by-side between the text elements in each file. The text properties such as level, color, weight, font, size, style is none; were exactly the same. However, they look different with different colors. What other controls are likely influencing the colors of this text?
Carl Myhill
Technical Support Engineer
Bentley Systems
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
