update with 08.11.09.655 over 08.11.09.578
Trying to install new Microstation update 2 and doesn't want to complete the process. It doesn't appear that files are being copied, but the process says that it completes.
If I start the install process again it says that .655 requires a re-install.
I start Microstation and it says that .578 is installed. Under Control panel it states that .655 is installed.
I ran the microstation.msi file from the Bentley downloads folder and files seemed to coopy.
Do I need to run all the .msi files manually?
Dan Bullock
