Hi everyone!
I have a problem with Microstation v8i (SELECTseries 3). I have used the program on the same computer for a time now but now it started to not save changes I have done in the file. For example: I have the color green on a line in a reference file. I attach this file in another file and the color is now yellow. I have to Update to levels to get the right color. I have tried to save through ctrl+f and the save button. When I open the file again the color changes back to the wrong color.
Thanks!
Regards,Seham
Hello Seham,
There are configuration variables and possibly a Key-in that may cause this. I am not clear on your workflow. Are you, for example;
Or have you a different workflow with nested references involved?
Hi Seham,
can you check in Level Manager what symbology are you changing (ByLevel or Override) and if Symbology Overrides is / is not switched in View Attributes?
I assume you want to change elements in ByLevel mode, so Symbology Overrides view attribute should be switched off.
Is it correct?
Jan
