Microstation 8Vi Selectseries 3.Not sure how I turned it off. I tried to turn it on with "accudraw dialog shortcuts" keyin command, but that does not help. I tried rebooting with no luck. The only thing that help is if I use an old version of user pref file (upf). But that is not a good solution. Any ideas? thanks
Answer Verified By: ball888
any other ideas why the dialog box disappeared?
Microstation select series 10 ver 08.11.09.919
