I seem to have some rendering problems with Microstation V8i. I don't believe I've pressed any button to cause this.
Is there a quick-fix to this?
Try following the suggestion listed here:
http://communities.bentley.com/products/microstation/w/microstation__wiki/4172
Specifically where it mentions:
Setting QV_D3DVERSION to a value of 9 (in the environment variables of Windows) will force MicroStation to use the DirectX 9 interface, starting with the next execution of MicroStation. If this removes the lines in your file this may be an indicator of how your graphic card driver interacts with the DirectX 11 API's.
The suggestion is if this is a desktop download the latest driver from the card manufacturer or if you have the latest you may need to roll the driver back to the previous driver before the latest.
If this is a laptop please consult the laptop vendor's website to get the latest certified NVIDIA driver for your device.
The following Bentley Community Wiki may also be of assistance in how to configure the QV_D3VERSION system variable. communities.bentley.com/.../17807.graphics-display-issues-solutions
Answer Verified By: Lars Anker-Rasch
