How to change drawing seed when placing a callout? Microstation V8i SS3
There is a Standard drawing seed file delivered with MicroStation called DrawingSeed.dgnlib.
This should be available in the Workspace System folder, for example C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\dgnlib\ and typically pointed to by the MS_DGNLIBLIST variable.
Check also if MS_DRAWINGSEED_LIBLIST is set or pointing to it.
Also have a look at these other post: communities.bentley.com/.../new-in-ss3-drawing-seeds-in-dgn-libraries
Unknown said:What if you want/need to have more than one (i.e. different projects, clients etc.)
MicroStation configuration files provide what you need. A configuration file defines configuration variables, such as MS_DGNLIBLIST. You can have multiple project configuration files (*.pcf) that define different sets of data for each project.
Unknown said:Can this library not live in the project?
Yes! Read about configuration files and other administration tools in MicroStation help.
