Microstation v8i: Is there any way to disable the annoying "This will exit microstation" nag screen that pops up if I exit by clicking the X in the top right hand corner? My mental response is usually along the lines of "Gosh, will it? I never knew that."
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
This alert dialog was something that appeared when exiting from MicroStation /J or V7.
Later versions of MicroStation V8 onwards no longer have this message.
What is the version of MicroStation you are currently using? If it is not /J or V7 then it may be as George has suggested. That you have a customized setting that has this message appearing on exit.
That's the message I'm getting, but I'm using v8i. MS_EXIT is undefined. I also had it on v8, on two different sysytems.
(edit - sorry, that's the respone to Andrew Bell's post)
Simon
If this is occurring in your current MicroStation V8i and previous versions of V8 then it would have to be a customization setting defined within your workspace when you login to MicroStation. I would suggest using the default workspace to see whether the settings is located as a configuration and as to whether this message still appears.
It would also be helpful if you could supply a debug file for when you start up MicroStation V8i. This would show whether you have any customizations affecting this operation.
http://communities.bentley.com/products/microstation/w/microstation__wiki/11081.how-to-quickly-generate-a-debug-file
I look forward to hearing from you soon.
