Dear All,
We have issue that, when we launch Microstation, this error all time appear, please help to fix this annoying:
Some of machines load both " Geopak and Microstation" and " ProjectWise V4" , but my machine only Microstation, but same error! my current micrstation version is V8i SS2 08 11 07 443 and other machines are V8i SS3 version 08.11.09.655 For my machine everytime when i launch it.. error always appear For other machines same too..every launching! Thanks
I can tell you that the files listed as not being found are in the value of your Microstation variable MS_DGNAPPS, which is defined somewhere in your CFG or UCF or PCF files. I'm not sure where else to search, where locating these files is concerned. My first guess is that the files aren't located where they should be, but I don't know what variable holds that path.
This article has some information related to msdebug.txt that you might be asked to upload: communities.bentley.com/.../8879.msdebug-file. It might be worth exploring that file for MS_DGNAPPS and any other variable Microstation has. The final value of each variable is at the bottom of the file; everything above the file tells you what the variable is at the time that the processor ran across that line of the CFG/UCF/PCF.
Unknown said: Dear All, We have issue that, when we launch Microstation, this error all time appear, please help to fix this annoying:
I think it looks like your IT dept or CAd manger has one generic install for msnt and verticals like bentley civil as you said you only have msnt ..
you can check your workspace config against others and see if they are the same yours should not mention the other applications..
Lorys
