Is there a way or application I can use to just see a .dgn attached referenc tree, instead of opening it through microstation?
The situation I'm running into is I have a huge project files, and I need to go through all my files to determine all the reference attached, and it would very useful if theer was a way I could just see the reference manager without opening each files one at a time, waiting for microstation to load up all the drawings.
Frank
Carl Myhill
Technical Support Engineer
Bentley Systems
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: geewizz
