I use V8i with Windows 7- 64 bit and 8Megs of RAM. Several times I have loaded dwg files (R2007) that probably originated from Inventor. When I make a small change to the file (adding a text note), or even just load the file, RAM usage shoots up to 6.6 or 6.8, and has on occasion caused the system to freeze.
Memory usage stays up even after the dwg file is closed and I have to restart the pc to reduce it.
It could be coincidental and not related to the dwg file but had never happened before I started working on the dwg files..
Can anyone suggest a fix?
Unknown said:I use V8i with Windows 7- 64 bit and 8Megs of RAM.
Can we assume you intended to write 8GByte of memory?
Unknown said:Several times I have loaded dwg files ... RAM usage shoots up to 6.6 or 6.8
MicroStation V8i is a 32-bit application and can normally use a maximum, imposed by the operating system, of 2GByte of memory. Something else must be using additional memory. That's not to say it's unrelated. If you use the Windows Task Manager, can you see any memory-hogging processes that might be responsible?
Unknown said:MicroStation V8i is a 32-bit application and can normally use a maximum, imposed by the operating system, of 2GByte of memory.
This is not quite true. Event though MicroStation is 32bit application, it can under some conditions uses more memory. Without more information about specific how environment is configured, it's possible MicroStation consumes mentioned 6 GB.
The best place to check how much memory and for what purposes MicroStation uses is About MicroStation dialog (menu Help > About...). There is Memory statistics part with more information.
With regards,
Jan
Unknown said:Can anyone suggest a fix?
I am not familiar with DWG files created by Inventor, but maybe the problem is in Object Enablers used in the file. Is there any information about OE in Message Center?
