I have loaded a dwg file that was probably created with Inventor, into my MicroStation v8i. When I add a note to the dwg file my physical memory usage rockets up and has caused my pc to freeze.
I use V8i with Windows 7- 64 bit and 8Megs of RAM. Several times I have loaded dwg files (R2007) that probably originated from Inventor. When I make a small change to the file (adding a text note), or even just load the file, RAM usage shoots up to 6.6 or 6.8, and has on occasion caused the system to freeze.
Memory usage stays up even after the dwg file is closed and I have to restart the pc to reduce it.
It could be coincidental and not related to the dwg file but had never happened before I started working on the dwg files..
Can anyone suggest a fix?
  • Hello Andrew.
    I apologise for taking so long to get back to you. The problem turned out to be with Windows not Microstation, and the pc was out of action for some time. Then I moved my office and have only recently got back on line.
    As I said the problem related to Windows but showed up while I was using Microstation, because that was the only program I was using on the pc at the time.
    Thanks for your assistance.
    Regards   Phil Leach.
