How do you import a .obj file into MicroStation. Using SS2. Do I have to convert it first? I have a bunch of .jpg and a .mtl file in the same directory as the .obj file. I see that others have done it, but I don't see anything under the import feature. Thanks
Double click on Bentley desktop icon, or within M-Sta go to File > Open. From the "File Open" dialog. Set the "Files of type:" to *.obj, find the location and open the file. You can then Select the element(s) and Copy to the clipboard and in a MicroStation file (3d) you can Paste into the file.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Answer Verified By: cswnow
FWIW, this thread should be continued in the duplicate thread over in the Visualization forum.
