I woudl like to be able to MAP CTRL-O to Fit
This way when I work in Microstation it woul doperate more clike Acrobat and adobe products. This is automatic for me and I now have gotten so used to it that it messing with me while in Mstation.
Using this to open files I find is not as frequest and there are other ways to do that as easy
I dont think this can be done easily as its a windows thing but I did reassign one of my 5 mouse buttons to the fit view command ...
I had it originally set to my Control F1 function key but when I got a 5 button mouse I realised I use fit view more often than any other tool so I figured since I wasnt using the on the left side two buttons I set the one closest my Thumb to use the fit view command instead... and the other I use to place fence by element...
Lorys
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Gerd,
I dont do alot of 3d but I find I need the tentative alot to check coordinates so my hand aches when I use the cord 2 fingers alot...
But I think if I needed to spend a long time in a 3d file its easy to change the settings then change back for every day 2d etc...
