Version 08.11.09.357
I have the text editor style set to Dialog Box, but when I select certain text to edit, it comes up in the word processor. Is there a reason for this? Can you change it anyway to come up in the dialog box?
Joe
In the Word Processor box there are 2 little "arrows" in the ruler to set the indent. The bottom arrow will set the indent after the first line.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Answer Verified By: Joseph Rusiewicz
You can click on any of the dots at the top and when you hit tab, it should bring you to that tick mark. It won't stop you from typing past the tick marks automatically however, so you'll have to hit tab when you get close to the end of each line. :/
Unknown said:I want to verify this as an answer, though it's not really the answer to the question of the original post. It is very helpful though. Do you know if there is a way to set a length of a line of text so that when it reaches that point it automatically goes to the next line at previously set indent?
keyin for line length is
LL=number
otherwise its in the advanced text style settings.. I can never find quickly but the LL does work.
Lorys
Unknown said: I have a construction sequence for a set of plans that are numbered and the text is indented from the numbers and the next line of text which is still in the same bullet needs to have its text line up with the text above. See the attached image. I've had issues in the past with getting the text to line up correctly using the word processor. .
A work around I have used to fix text like this before is by copy pasting into word where the tools are easier to use and the result is wysiwg
then past back in to a new empty text editor word processor dialog ..
I've not had a lot of success fixing the format of someone elses text with the word processor and the indent and tabs options..
