Is there a tool in MicroStation that will let me delete colinear/redundant vertices?
I assume you have looked at the 'Delete Vertex' tool? It might be too much of a manual process to use this for this situation though....
Excellent illustration!
Unknown said:Is there a tool in MicroStation that will let me delete colinear vertices?
Whence did those excess vertices originate? That sort of geometry cleanup tool is provided by GIS tools, such as Bentley Map.
Hi Joe,
if there are duplicated vertices you can use this MicroStation VBA macro.
I don't know about similar tool to remove colinear vertices as it's a bit more complex topic. But if you know your will work with a similar file often, it looks wise to think to create such tool. To use Delete Vertex manually will work, but requires quite long time to delete all vertices.
With regards,
Jan
