I'm trying to 'copy parallel' a smartline by distance. If there are any elevation changes in the original line (and there always are) the copied line gets skewed in elevation which causes my XY to be off. This is very frustrating and time consuming. Is there a way to 'copy parallel" by distance and maintain the elevations of the original smartline without having to buy a third party software to achieve this simple task?Thank you!
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
