Draft Tools
I see where this has been asked before, but I would really like the old Draft Tools to be compiled to work with v8i.  The new tools available under the detailing toolbar are so convoluted and require so much in the way of setup that for small jobs it's just not worth the trouble.  The old draft tools was simple yet elegant in that it generated titles, section callouts, leaders it a very convenient package, with a simple configuration dialog to control the symbology.  I can maybe see if I was working on a 50+ page project then the new system has it's merits, but all this work for really small projects is unbearable. I feel like now I've have to go back in time maybe 15 years to develop custom cells that will not perform nearly as well as the old Draft Tools.  No developer is developing these types of crucial tools anymore either, so the simple drafting needs of every project has become so much more complicated.
Greg McGowan
CAD Manager
Portland Parks & Recreation
  • I realize the new tools are supposed to be superior, but they require so much more to setup and use than the old Draft Tools. It's really to bad that Bentley is not willing to listen to their customers anymore. I've used this software since it was PsudoStation and in years past they really did listen to the users. I guess we have to hope and pray that some kind developer will come along and compile these tools for us. It's not just the callout tools that Lorys alluded too, but it's also the place title, place section marker, all the tools and their configuration were so much simpler to use. Now we have to setup saved views of reference files, and the actual configuration of what you want to show graphically is much more complicated. Really sad day for our advancement and use of this product. Guess we will have to go back to developing enter data field cells, or tag enabled cells to get close to what Draftools did before.
  • [admin note: This thread veered off-topic, so that part of the thread was split and moved to the MicroStation CONNECT Edition Early Access Program community]
  • If you place the new markers straight out of the box and just edit their text - replacing the fields with your manual entries - does that work for you? What specifically are you missing? Do you need your own "looks"?
